Don't mash the throttle. Slowly take off and slowly get up to speed. Going from zero to full throttle is a great way to mess up the gears.I have a 1/10 brushed 2wd Ruckus. I just put a 4000kv tazer brushles combo in. I know the gears will break soon. But what is the best adjustments i can make so that the gears last the longest?
Thank youDon't mash the throttle. Slowly take off and slowly get up to speed. Going from zero to full throttle is a great way to mess up the gears.
Also, if you are doing jumps with your ECX Ruckus - don't be using the throttle right as it's landing. Without a doubt that is a sure fire way of blowing diffs and causing other havoc.
Awsome. I dont know if anyone has noticed this but my brushed ruckus came out of the box with the wheels loose and the slipper clutch cranked all the way down.Not sure how to save the stock ones so I'd just upgrade them.
Thank you.Proper mesh on spur/pinion and replace diff gears with metal upgrade. You could loosen the slipper a bit to gain some borrowed time for the diff gears but eventually you’ll smoke the slipper pad if you run it loose enough to provide adequate protection from a heavy foot ... I mean heavy finger. Also, watch hard landing under acceleration. Backflips come to mind. Going from freewheeling in the air to sudden high traction on landings can wreak havoc on your driveline in general.
