Need more info you can help I installed a new motor but it doesn't come close enough to touch the spur gear to make it turn out like it's supposed to he acts like it's tripping on it as you turn it. To me there's too much clearance what can I doWe have four cars all brushless only one has a metal spur gear. The reason that one is metal is because that's what we had spare. We had a motor come loose. So far this is the only time we have stripped a spur gear. We run our slippers two full turns out from fully tightened down
What size pinion are you using? Please, you can remove the motor and file out the slot with a jeweler's file to extend its length. If you are using a small pinion you will have to do some filling.
