wizardwerx8
- Location
- Springfield MO
Thanks I will do that. Now Im having chrager issues. I cant get my venom ac sport to charge my lipo.Get rid of the in and out play in the axle. Pull the tires out and push them in, you will see what I am talking about. There is a lot of slop.
Shims or aluminum hubs all around.
The battery when plugged in will not charge. As if the charger couldn't detect the battery. But when i got home this morning from work it started charging. The battery was completely dead. Which is weird because I have a low voltage cut off. Thanks sc302 for the tip on charging on nimh setting. If this happens again i will definitely try it. Would it be possible my low voltage cutoff is set to low? It is currently set at the default setting of 3.2 volts.What's it doing?
Might have to charge on NiMH for 10 min then switch to LiPo. Take out balance plug when you charge on NiMH. When the voltage too low, they won't charge on LiPo.
Sometimes, even when set, doesn't work properly is the only thing I can guess. If the voltage is too low it will not do anything other than beep, nimh doesn't care it will still charge or try to.The battery when plugged in will not charge. As if the charger couldn't detect the battery. But when i got home this morning from work it started charging. The battery was completely dead. Which is weird because I have a low voltage cut off. Thanks sc302 for the tip on charging on NiMH setting. If this happens again i will definitely try it. Would it be possible my low voltage cutoff is set to low? It is currently set at the default setting of 3.2 volts.
Thanks for all the input guys. I think I might have killed my LiPo.charged the battery yesterday morning to full charge. brought the truck to work tonight and the battery wont charge again. I tried the tip sc302 gave me a few post back and nothing. Whats the biggest 3s LiPo I can safely run with my 70a ESC?
I went to a friends house yesterday and tryied to charge a week old LiPo. And my balance port would recognize his battery either. Time for a new charger. Im looking at a venom pro duo or a hitec x2.
