xlDooM
I replaced my servo with a Power HD 1501MG today and the steering performance was a lot better. I did notice however, that the screw which holds the front end of the steering arm to the "collarbone" (no idea what it's called, the thing which has the inside ball studs for the turnbuckles on it) had tightened itself somehow, which caused the servo saver to open a bit all the time (even when recentering for example, giving untrimmable results).
I superglued my caster block shoulder screws after losing two and they hold out fine. I tightened them all the way (not hard though, as I feel they'll just burrow plastic out of the blocks) and the shoulders are long enough to prevent it from sticking. I think these are the screws some of you were saying cause stiction when too tight? I must have different screws, they're from the replacement shoulder screw set (ECX1065).
