Except for the brushless upgrade its all stock. Surface is dirtAre you running stock tires still?
What types of surface you running on?
Anything done with the suspension?
So many questions........you can't put more power to the wheels without changing up your suspension setup and tires.
Many thanks. I will try your suggestions I’m loving this hobby but I have a Tom to learnA few good things to do is mess around with your suspension. You can use like 30 to 40 weight shock oil. I believe you get extra pistons for your shock inners. Try using a three hole or lighter spring tension for springs. There is a few you tube videos out there on Torments.
Also, the stock tires are junk. They are super hard.....J concepts make some really nice tires. Proline are good too, just aalittle expensive. You can also refer to another forum on here for tires. I posted some that I am running currently on my basher, eBay knock offs.
I think this is the thread you refer to?
