So I had a similar issue a while ago, where if I pinned the throttle from a dead stop it would cut out, and need to be turned off and on again. It was a loose dirty connection, that would work at a low amp draw, but not a high amp draw. I don't remeber which one, but I cleaned everything I could, then I put penetrox (or nolox) on every plug on the vehicle. Could be your issue too. Could be impossible to even see, so if you look and don't see anything obvious, I'd still recommend getting some penetrox (from home depot like stores, or an electrical distribution store, as it's for electrical connections), and use a toothpick or small screw driver to put a little on each pin of your reciever. It's sticky and messy, and you don't need much at all. It'll make a much better connection. I even have a light coat of it on my battery connectors.
