Joe Schmoe
Post your favorite Mod
Extreme Racing G-10 Chassis extension. This mod completely changed my vehicles handling and performance. Also helped me keep the front end down.Post your favorite Mod
You need to buy a $1 low voltage alarm from ebay. Google how to use it, or ask on here... it will protect your LiPo battery from over discharging which is dangerous for lithium batteries., youll need a LiPo compatible charger and a charging bag, you may also need to solder new connectors onto your new battery to fit your RC connector.
The low voltage alarm will not protect your battery. It will tell you when the cell voltage is lower than the set level. User error can still damage your battery if you ignore the alarm beeping at you.![]()
Bigpoppa99,Here is my mods so far. It's hard to call these mods, although they technically are mods, to me they are more of a requirement.
-Helios RC 2s LiPo 5200mah
-Spot-On RC velcro battery strap
-Hot Racing aluminum steering knuckles
-LiPo battery voltage alarm w/ balance lead extension
-Team Fast Eddy bearing kit
