Chuckstasy
Ouch! I feel your pain
Surely theres something else wrong? I mean 10 minutes omg!
Is your Ruckus 2WD or 4WD?i double checked everything but it's not the right product for the Ruckus.
Hello, I'm new here
Had already read through everything here and still wanted to ask again which drive shaft you can recommend.
Have a Ruckus 2wd brushless
Cool tires. Do you like them? What are they?Here is a picture of the car
Just to test if it is possible to swap left and right. Should work with the RPM arms but the design of the stock ones is more suitable for new shock mounting holes.Ive had my eye on those MIP X duties too...they look amazing.
@JvG did u swap out RPM Ruckus A arms for stock Ruckus A arms? Why?
I use 2s 45c lipos. Here is a picture of the car
Hi Matze, same price here in the Netherlands.The cost here in Germany 50 €. Is there still a cheap solution?
Yep, the Ruckus is really cheap in comparisson to its competitors so even with 50 euro axles it is still cheap. You can try the cheaper plastic Traxxas axles from the slash 4x4. I've read that they hold up better than the stock ECX ones but have no experience with them.Here in Germany they are too expensive. The ecx cost here in the brushless version new 150 €. Wanted now not so expensive drive shafts buy for it.
