Mira-rc-man
and can u fit other tbone bumbers on?
Call Horizon, they’ll hook you up.Ran a Lipo battery 10 minutes in my buggy and it killed my esc/receiver combo. Lipo was a 2c 7.4 5200 20c. What a bummer. Be aware not as Lipo friendly as they say!
I did. They said it was the esc.. I asked if it is under warranty ... Never heard back.. Sad..Call Horizon, they’ll hook you up.
Hot Racing and ecx make them. I took the rear aluminum hubs out of mine and went back to plastic. The aluminum was too stiff in the rear and prematurely toasting wheel bearings. I found the bearings to last twice as long with plastic because it flexes a little.hello all
are there any upgraded metal hub carriers and hubs that fit the amp maybe from a traxxas or something
cheers
Servo - The stock steering servo seems a bit under powered, to remedy simply upgrade the servo to something like the Power HD 1501MG, MG996R, or Hitec HS5645MG.
Yes sirhttps://www.fasteddybearings.com/ecx-1-10-2wd-amp-sealed-bearing-kit/
Will These be the right ones for my Amp MT? 1/10th 2WD?
Tysm for clarification!Yes sir
ECX13003 is discontinued. Is there any new receiver that works with the stock transmitter? My AMP MT is quite new, how do I know if it is V3 or V4.
many thanks,
I've emailed Horizon Hobby that exact question, I'll let you know their response. I couldn't find anything on Google that suggests the ECX10003 transmitter can be bound to any other receiver so we'll see how they respond.
I ended up replacing the RX/ESC combo so a moot point for me now but I am interested in their answer.
